problem in my app when I active security in service on Arcgis server.
3414
04-19-2016 05:09 AM
EltonLeite
Hello friends,
I'm having problem in my app when I active security in service on Arcgis server.
I active and try to acess my app, and the follow error appear:
arcgis app.PNGjava.lang.NullPointerException: Input stream is null.
I'm Redirect to this link "https://XXXX.pmjg.lan/XXXXX/tokens//home/signin.html?returnUrl=http%3A//XXXXX.pmjg.lan/XXXX/ ", but with I pause app execution I see this error on console:
jimu.js init...
Load Config: 3830.082ms
Error: Token Required(…)
Configurations:
Arcgis Server 10.4
Portal 10.4
App create with App builder 1.3
RandallWilliams
How is your app passing credentials to the token service?
Are you using a proxy page?
RebeccaStrauch__GISP
Although I can't answer your question right off, below are some links and a tutorial to help with proxies.  I've been using the older 0.9 version of the proxy and I'm working on updating to the newer version myself.
Setting up a Proxy | Support Services Blog
Setting up a proxy with Web AppBuilder Developer Edition | Support Services Blog
Using the proxy | Guide | ArcGIS API for JavaScript
ArcGIS Online Implementation Guidance—Trust ArcGIS | ArcGIS
I have some other links re: proxies and secure services on Web AppBuilder Developer Edition - Customization Resource List     ...under the "pinned pages/links" section.
btw - I'm also still using 10.2.2 but plan to upgrade to 10.4.1 so will follow this thread.
MuglaCbs1
Hi, its an old post but i have same problem too.
i am using Arcgis server active directory authorization for securing rest services.
when i add a secured service to portal 10.6 i can see a login screen and i can use my active directory user credentials to see layer in my webmap.
But when i use that webmap in an application made with WAB developer edition and deploy my own server, i have that same error with blank white page just after seeing my basemap;
Redirected page adres. (cbs is my web adaptor name that same for server and portal side.yyy aplication foldername in wwwroot folder.):
https://xxx.xxx/cbs/tokens//home/signin.html?returnUrl=https%3A//xxx.xxx/yyy/
Also i get that error message with this page;
We want to use our active directory user credentials to authorize rest service address for WAB web applications .
Thank you.
web appbuilder error‌ arcgisserver‌ arcgisportal rest service token #web-appbuilder
ArcGIS GIS Server Advanced 10.6
Arcgis Portal 10.6
WebApp Builder Developer Ed. 2.8
NonFederated Server-Portal
