Preferred order of stopping Portal, ArcGIS Server & ArcGIS Datastore?
209
11-10-2020 06:31 AM
PhilippeVan_De_Vreken
Hi folks !
What is the best order to stop the services of Portal, ArcGIS Server and the ArcGIS Datastore? Is there a preferred order?
And what is the best order to start them again? Can Esri give some advice on that?
Thanks a lot!
Reply
GeoJosh
There is no Esri-recommended order in which the Enterprise components should be stopped/started. However, Portal by far has the longest startup time. With that in mind, I usually restart the services in this order:
  1. Portal
  2. Server
  3. Data Store
Best,
Josh
PhilippeVanDeVreken
Thanks Joshua!
Reply
