All in and earlier post, 4 years ago, it was suggested that correct stop order for an ArcGIS Enterprise deployment is: Data Store, Server and last Portal. It also suggests that the start up order is the same.
Is this still considered correct?
As mentioned in the title I have a high availability system in Azure with a primary 01 and a secondary 02 VM for each component.
Assuming that the starting order is correct, would the shut down order be: Data Store 01, Data Store 02, Server 01, Server 02, Portal 01, Portal 02?
Or would the shut down order be: Data Store 01, Server 01, Portal 01, Data Store 02, Server 02 and Portal 02?
It was also stated that the start up order should be the same.
Assuming that the starting order is the same, would the start order be: Data Store 01, Data Store 02, Server 01, Server 02, Portal 01, Portal 02?
Or would the start order be: Data Store 01, Server 01, Portal 01, Data Store 02, Server 02 and Portal 02?
Thanks for any consideration of and answers to my questions.
