Portal Machine Name
1855
02-19-2018 05:41 AM
MatsHardy
I have a Win 2008 R2 server aaa.yyy.com, then I installed Portal on the server. The Portal site can be created but when I access portaladmin -> machines, I found the machine name is aaa instead of aaa.yyy.com, so that I cannot import domain certificate to Portal. Are there any configurations I need to cater?
by Anonymous User
Not applicable
Hello Mats,
First, I would like to confirm if the Portal site is accessible through the fully qualified name when accessing different endpoints:
  •  https://aaa.yyy.com:7443/arcgis/home
  •  https://aaa.yyy.com:7443/arcgis/portaladmin
  •  https://aaa.yyy.com:7443/arcgis/sharing/info
    • Note: Portal 10.5.1+ will need to be  https://aaa.yyy.com:7443/arcgis/sharing/rest/info
If the Portal site is not reachable over the fully qualified name aaa.yyy.com, recheck that the machine is properly joined to the domain.
Next, review the [C:\Windows\System32\drivers\etc\hosts] for any entries, especially entries that are not fully qualified or incorrect. Portal prefers to use localhost to identify itself, so if entries specify localhost to the shortname aaa, this may be the issue.
If DNS (Domain Name System) records are incorrect, this may also confuse Portal. Use the Command Line tool nslookup to confirm the machine can resolve localhost, aaa.yyy.com, and the IP address for aaa.yyy.com (called a reverse lookup).
Example from cmd.exe:
> nslookup aaa.yyy.com
Server: dns.yyy.com  // DNS server being queried
Address: 10.11.12.13 // IP address of DNS server being queried
Address:  10.20.30.40 // IP address on record for aaa.yyy.com
I am interested if ArcGIS Server is also installed on the same system, does it also pick up the machine name only? If so, what version of ArcGIS Products are installed?
- Austin
MatsHardy
Thanks for your reply. I have found the following entry in C:\Windows\System32\drivers\etc\hosts:
10.90.65.67 bbb aaa aaa.yyy.com
It is likely the entry lead to the problem. Are there any ways to modify Portal hostname after installation?
JayantaPoddar
Can I rename the machine where Portal for ArcGIS is installed?
No, this is not currently supported. If you rename the machine, your portal will be unavailable.
Common problems and solutions—Portal for ArcGIS (10.6) | ArcGIS Enterprise
Think Location
