Portal for ArcGIS upgrade from 10.6.1 to 10.7 failed
1903
21
04-25-2019 02:57 AM
NicolasGIS
I faced an error while upgrading from Portal for ArcGIS 10.6.1 to Portal for ArcGIS 10.7.
The following error occurred during the upgrade:
Digging into the log in C:\arcgisportal\logs\FQDN\portal, I noticed the following error:
<Msg time="2019-04-25T10:19:54,94" type="INFO" code="209081" source="Portal Admin" process="3436" thread="1" methodName="" machine="FQDN" user="" elapsed="" requestID="">Postgres DB upgrade response
could not open version file: C:\arcgisportal\db/PG_VERSION
Failure, exiting
.</Msg>
As you can noticed, there is a mix of backslash and forwardslash as the file does exist in C:\arcgisportal\db\PG_VERSION but of course C:\arcgisportal\db/PG_VERSION is not a correct path.
Operating System details: Windows Server 2016 Standard
Any idea ?
Thanks
LorenzMeyer1
New Contributor III
In our case it was in fact a missmatch of the regional settings from the source portal machine to the destination portal machine. After changing all the regional settings and formats to the same settings as on the source system, I could import the old *.webgissite (webgisdr backup file) into the new portal and then upgrade the portal from 10.6.1 to 10.7.1 without getting any postgressql error. Luckily our machines are cloud based and I had for every migration step a snapshot of the disks, so in case of errors I could revert back and try again.
BarbaraS
New Contributor III
