Port number: ???ESRI license server??? and ???ERDAS license Server???,
7763
10
03-29-2013 12:40 AM
JamalNUMAN
Legendary Contributor
We are trying to install the ???ECW for ArcGIS Server 10.1 Version 11.1??? and still confronting issues as shown in the screenshots below
[ATTACH=CONFIG]23065[/ATTACH], [ATTACH=CONFIG]23066[/ATTACH], [ATTACH=CONFIG]23067[/ATTACH], [ATTACH=CONFIG]23068[/ATTACH]
We were advised to check if there is a conflict in port number between ESRI license server and ERDAS license Server
My issue now that I have no idea how to check the port number taken by the ArcGIS server
Thank you
Best
Jamal
Jamal Numan
by Anonymous User
Not applicable
Original User: Tmontefusco
The path to the license manager log file for 10.1 is: C:\Program Files (x86)\ArcGIS\License10.1\bin\lmgrd9.log
Yes, if editing the service.txt
An example from my machine:
SERVER this_host ANY 27000
VENDOR ARCGIS PORT=27004
INCREMENT ACT ARCGIS 1 permanent 1 0C8080D1B377B6E205C6 \
        vendor_info=734XCAP6LGGLCXJ9S195
The second entry (VENDOR ARCGIS PORT) is your choice. Some people choose 27009.
Once you do this, restart License Manager service, then add the exclusions in your Firewall.
by Anonymous User
Not applicable
Original User: bubbahey25
If you want to check what port is being used, check the license manager log file.  If using a Firewall,  you need to lock down the ports.
See:
Configure the ArcGIS License Manager to work through a firewall
http://resources.arcgis.com/en/help/install-guides/license-manager/10.1/index.html#//00790000000w000...
I noticed you are also using ERDAS license manager.  ArcGIS License Manager doesn't like competing with other license managers (it can be done though).  See this article, not sure if it still applies:
Problem:  ESRI and ERDAS license managers may conflict when installed on the same computer
http://support.esri.com/en/knowledgebase/techarticles/detail/25194
My advice: If you can put license manager on it's own machine, life will be easier.
BubbaHey
See this forum thread. It's about the conflict between Autocad license manager and ArcGIS LM, but points still apply. See ESRI MVP Stuart Forte's excellent comments:
http://forums.arcgis.com/threads/62593-ArcGIS-License-Manager-10.1-and-AutoCAD-issues
by Anonymous User
Not applicable
Original User: Jamal432@gmail.com
See:
Many thanks Bubba for the answer,
Could you please elebaorate more where can I find the �??license manager log file�?�
Best
Jamal
JamalNUMAN
I think the provided link is irrelevant! Correct?
Jamal Numan
JamalNUMAN
See:
Is the 27000 is the port number in my case?
[ATTACH=CONFIG]23079[/ATTACH]
Jamal Numan
by Anonymous User
Not applicable
BubbaHey
Tom is correct. The link I posted: http://forums.arcgis.com/threads/62593-ArcGIS-License-Manager-10.1-and-AutoCAD-issues is correct. What I wanted you (and others) to read is Stuart F's excellent explanation on how licensing  and license manager works.
In my experience this issue is usually:
1. Firewall related, if so, follow that Help article
2 Conflict with 3rd party license manager, such as AutoCad. I usually do the same  - follow the article because it locks the ports to ArcGIS
by Anonymous User
Not applicable
Many thanks guys for the help, this very useful.
Is there any sort of consequences if the port number is changed?
BubbaHey
I don't think so, unless the port is already in use.
