Pop-Up created in Pro does not work when published to Portal
178
01-07-2020 02:48 PM
Occasional Contributor III
I have a hunch that this is a bug, but I'll ask anyway and see if others are having the same experience.
ArcPro version 2.4.3
ArcGIS Enterprise 10.7.1
Steps:
- Created a web map in Pro. Configured the pop-up using the text option:
- Successfully tested the pop up in Pro:
- Published the entire map as a web layer (Share tab > Share as group > Publish Web Layer). Only checked the box for Map Image under Layer Type.
- Added new layer to a web map. Clicked on point and got this:
All of the dynamic fields that should be pulling from the attribute table are left blank. I checked the pop-up configuration in the Portal web map, and it looks right:
Anyone experiencing this issue? Is there a fix?
Reply
I answered my own question mere minutes later.
When you create the pop-up in Pro, do not remove the Fields option. Just add in the Text configuration and leave the Fields as-is.
I had deleted the Fields option (circled in red) before I published. If you have a Text option, it will be used for your Portal web map pop-ups.
