Permissions for federated server seem to be not working
2982
10-26-2017 03:51 AM
GMVGMV
Hello!
Lets say I have 3 services: service1, service2 and service3 (each with 2 layers, but I don't think it matters). For each service I have editor tracking enabled. My Server is federated with Portal, so each time I publish a service it gets automatically added as an item in Portal. Server and Portal are version 10.5.
I want to properly assign permissions for each user, say: user1 has access to service1, service2 and service3, and user2 does not (while both have access to some other services). Both users are level 2 users, so they can edit data in all 3 services.
As long as I know such permissions are set in arcgis manager ([Arcgis Server]/arcgis/manager) and in case of federated server in Portal (it is possible to do that over Arcgis Server api, but any changes are reflected on respective Portal item). Also I am aware, that an item in Portal can be shared with a group, not with a role.
I tested 3 slightly different options, this is how:
I created a map (lets call it map1) as administrator, and I do not share it with anyone.
Now I open My Content on Portal, click Add Item->From the Web. I paste url of service2, and I get a popup similar to the one in the attachment. I choose "Store credentials" and fill in my administrator password - I expected only administrator can access that service. I named the created item "service2_stored".
Now I add service3 the same way as service2 in previous point, but I choose to not store credentials of my admin account. This way I created item service3_notStored.
Next I open map1 in mapviewer ([Portal for Arcgis]/arcgis/home/webmap), click on Add->Search for Layers->Find "service1" in "My Content" (this is item automatically added to Portal when I published service), and it was never shared with anyone. Then I add service2_stored and service3_notStored in a similar way.
Now I log in as user2 and open map1 in mapviewer - I just copy the link from the browser, I did not bother to look for it in My Content. First suprise it that user2 can access map1 at all - I expected some sort of insufficient permission error. Even more astounding, user2 was able to access and edit data in service1 and service3_notStored - although I never granted ANYONE permission to do it, on the Server or Portal. Now the interesting part is that I was not able to access service2_stored, which is exactly what I wanted. My question is, why does this work differently when I store credentials???
I wanted to add all services the way I explained service2_stored, but now I realized when I do it, the editor tracking assigns username and password I stored. If I could just switch it, so it stores user who actually made the changes, it would be enough to solve my problems.
Still, I think something is not working properly here. Did I forget about some step?
Regards.
GMVGMV
I guess I should close the topic, as it turned out the problem was due to my mistake.
To achieve my initial goal I had to create new custom roles (aforementioned Admin, Editor and Advanced). It turned out that I misunderstood options during creating role:
I thought if I select them user will be able to see content only if it is shared with him, not see literally all services in the system. When I unchecked these options previously visible services disappeared.
Maybe this will help someone.
BR
DerekLaw
Esri Esteemed Contributor
Hi GMV,
Your post is a little confusing, because I am not clear on your workflow. But I will try and address some of your individual statements:
This statement seems to contradict itself. You say that user 2 does not have access to services 1-3, so it cannot be able to edit any of them.
Q: How was security set for service 2? It is not clear if this service is from a federated or non-federated Server site.
Once you save credentials to access a secured service with the Portal item, then any Portal member who has access permissions to the item, will be able to access its content, because you saved credentials with it.
Q2: Again, it is not clear on how security was set for service 3?
In this case, when a Portal member who has access permissions to the Portal item attempts to access its content, they will be prompted to provide login credentials to view service 3.
Q3: Did you explicitly save the web map? If so, did you share this saved web map so user2 has permissions to access it?
Again, not clear on your specific workflow.
Q4: Was this is the same web browser, but a different tab? I suspect that perhaps the administrator login was cached in the browser.
This is expected behavior.
Hope this helps,
GMVGMV
Ok, I will try to explain the situation + workflow a bit better. Of course my environment is the same:
One ArcGIS Server (where I publish the services) federated with one Portal for ArcGIS (where I have items).
I have 3 users (all level 2 in Portal)
  • Admin
  • Editor
  • Advanced
I have two services:
  • Service1
  • Service2
My environment is:
  • ArcGIS for server federated with Portal with data for Services coming from a registered Data Store (database).
What I want to achieve?
To have a Web Map: Map where I want to add Service1 and Service2. Although Service2 should only be visible and editable by Advanced. Furthermore, I want to have editor tracking for those services.
What I did in order to achieve that?
Using Admin, I published Service1 and Service2. I shared Service1 to Editor and Advanced, and Service2 only to Advanced. I created a map where I added Service1 and Service2.
What I see?
I log in as Editor and I see/can edit Service1 (I want this) and Service2 (I don't want this), I log in as Advanced and I see/can edit Service1 and Service2 (those are fine). I expect to see/edit only with Advanced.
Because that was not working I tried the following:
Instead of using the Service2 straight ahead from the Portal Item which is automatically generated because of the Server being federated, I grab the Service definition URL from the Server and I try to create a new Portal item from it.
When I do so, I have the two possibilities shown in the attachment, so just out of curiosity I published Service2_credentials and Service2_no_credentials following both of the options from the attachment.
After adding those, again, I shared Service2_* only with Advanced.
Following, I added Service2_* to Map.
My surprise now is that altough Service2, Service2_credentials and Service2_no_credentials have the same Sharing rules.
Now I log in as Editor to the map and I see/can edit:
  • Service1 (expected)
  • Service2 (not expected)
  • Service2_no_credentials(not expected) - it does not prompt me for credentials; maybe it uses Editor, even though it is not shared with Editor?
  • I cannot see and I cannot edit Service2_credentials (expected).
Thus, I said, weird but perfect. Let's just keep Service2_credentials. However, I recognized that by doing so, editor tracking will always be assigned to the "saved credentials", so we are not tracking the real editor. I know that this is expected behaviour, but that is why we cannot use this particular method.
I'm wondering if there's any way to obtain what I want.
Thanks for the reply.
GMVGMV
BR
