Patching Server that isn't part of a Site
1467
02-05-2020 12:14 PM
CuyahogaGIS
Can you apply all the available patches to a fresh install of ArcGIS Server before joining it to an existing Site? We're getting ready to replace some VM ArcGIS Servers with physical servers.
I've done a fresh install of ArcGIS 10.6.1 and it has some patches available. Does the Server need to be setup with a config_store and be part of a Site to install the patches?
Tags (1)
jill_es
Glad to hear everything is working for you!  As you mentioned, you can patch before or after creating a site - the results are the same but it can be faster before the site is created.
CuyahogaGIS
Got a response on a Slack channel from someone at Esri and they said it's better to apply before creating the site. Functionally identical but the patching process will be faster if no site is created yet.
Been patching the past couple hours without issue.
jill_es
CuyahogaGIS
I'm trying to mark your reply as the answer but the 'Mark Correct' button doesn't seem to do anything.
jill_es
Thanks for letting me know, I reported this to the GeoNet team and marked the answer as correct.
