Our system infos are ArcSDE 9.3.1 and Oracle 11.2.0.4 and there are some bugs.
3682
10-09-2014 01:22 AM
CBSSube_Mudurlugu
1. MXT prefixed files are displayed in ArcCatalog.
2. When editing in graphical layers, some features on some of these layers are not shown. After reconsile/post and compress, these errors are repaired.
in sde_esri_sde.log file, the below lines occur in this error
[Thu Oct 02 14:04:43 2014] [7761] [CBS-XXYYZZ] db_array_fetch_spix_recs OCI Fetch Error (13050)
[Thu Oct 02 14:04:43 2014] [7761] [CBS-XXYYZZ] load_buffer error -51 on ST_STREET, rowid -1
Thanks.
VinceAngelo
Esri Esteemed Contributor
Incompatibility between the retired ArcGIS 9.3.1 and brand new 11.2.0.4 would not be surprising, but this particular error may be due to a low-level geometry storage issue.  What geometry storage are you using? (SDEBINARY / SDELOB / SDO_GEOMETRY / ST_GEOMETRY)
Does your Oracle alert log have ORA-13050 errors in it?
     ORA-13050:    unable to construct spatial object
     Cause:    This is an internal error.
     Action:    Contact Oracle Support Services.
- V
