Need to undo "move edits to base"
3930
09-25-2014 06:35 AM
ErikBlake
I have a table in my sde that i want to replicate. However when it was registered the "move edits to base" was checked. Therefore I can not replicate it. If I just un-register then re-register the table will this fix my problem.
by Anonymous User
Not applicable
Hi Erik,
See the ArcGIS Documentation
ArcGIS Help (10.2, 10.2.1, and 10.2.2)
When you unregister a feature class, the delta tables are dropped from the database—that means all versioned edits that were made but not posted will be lost. To prevent these edits from being lost, either compress all the edits to the base table before unregistering the data or compress them to the DEFAULT version from the Unregister As Versioned dialog box. The software prompts you to compress the edits to the base table when you attempt to unregister a feature class as versioned.
Regards,
Richard
by Anonymous User
Not applicable
Hi Erik,
Regards,
Richard
