Moving ArcGIS Desktop and Server installed on the C: drive to a new D: drive
5925
9
01-27-2016 07:23 AM
DaveTenney
Occasional Contributor III
All,
we currently have ArcGIS Desktop and Server installed on the C: drive on a server machine. We also have a site created with services with that install. is there a preferred way moving everything over to the new 😧 drive thats been placed on the machine?
    thanks for the help, newbie here looking for help!
Dave
Subject was edited by: Timothy Hales
JakeSkinner
Esri Esteemed Contributor
Hi Dave,
You can easily change the server directories using ArcGIS Server Manager:
Editing a server directory in Manager—Documentation (10.3 and 10.3.1) | ArcGIS for Server
However, if you are looking to change the entire installation, I believe you will have to perform an uninstall/reinstall.  I would recommend looking into backing up and restoring your ArcGIS Server Site Configuration:
Back up and restore your ArcGIS Server site configuration—Documentation (10.3 and 10.3.1) | ArcGIS f...
ChrisSmith7
Are you just running out of space on C:\? If so, maybe this thread​ will help you to offload some of that to D:\
JakeSkinner
Hi Dave,
RebeccaStrauch__GISP
To add to what Jake mention, I like to split the ArcGIS Server install between my C and D, keeping all the caches and output on D (although I have multiple output locations, including some one other server ---web if I remember correctly machines).
This is how I set our up (for an example....never hurts to get a look at how others do it)
EDIT: should have included this graphic too...
As for the Desktop, I keep that install on C, but have most of my MXD and FGDB on D (or elsewhere).
DaveTenney
thank you all so much for your help....it is greatly appreciated!
   we are trying to mirror real world servers that everything on the D drive. currently on our local server we have everything on the C drive. so were in the process of moving everything.
     thanks again for your help!
Dave
DaveTenney
forgot to mention that we do keep our caches and output separate as well.
  current state:
    install is on c: drive
    outputs are on t: drive
dave
DaveTenney
will reinstalling server and specifying the root directories to use what was used for the previous install for your site overwrite the existing directories and their contents?
   dave
Dave, can you maybe change your question header to something a bit more descriptive?  Another poster today might have found this if the title was a bit more related to the question.  Luckily, I remembered this post and gave him the link.
I'm not sure how easy that is to do, but I'll cc Timothy Hales​  in case it's harder than just editing.
BTW - I think the thread # remains the same (for links) ...just the title changes....at least that is my understanding.
TimothyHales
Esri Notable Contributor
Rebecca Strauch, GISP​ You are correct, you can change the title without affecting the URL. I have updated the question title/subject to a more descriptive text. Thanks!
DaveTenney
All,
   well after a great learning day and baptism by fire, it was a successful day!
everything is transferred over to d: and our site is up and running like it never went away.
still a lot to learn so im sure you will all see many more posts/questions to come in the future.
thanks again!
dave
