Migrating from AWS to Azure Enterprise
164
a month ago
JustinPence2
We are looking to migrated from AWS to Azure in our Single Machine Deployment of ArcGIS Enterprise, version 11.3.  We tried to migrate using az migrate before contacting ESRI support, and ran into several issues.  Speaking with ESRI support, they recommend using webgisdr.
Anyone have success doing this, or something similar.  Any gotchas, beyond the documentation to be aware of.  Our first initial installation was 10.5.1, meaning Enterprise Builder, Cloud Builder, etc was not available.  Therefore the installation was manual (which I was not a part of at the time).  I am not sure if I will need to install and configure each component manually for Enterprise on the instance in Azure, or if I can use Enterprise/Cloud Builder, then move content over using webgisdr.
Any insights would be helpful.
RyanUthoff
MVP Regular Contributor
The biggest gotcha I can think of right off (which might not necessarily be a gotcha, but something to be aware of) is you'll need to work through your hostname resolution dealing with your public URLs. If your original environment is going to stay online during the migration, you might need to do some hostname resolution stuff until you're ready to make the cutover to your new environment. Of course, this all depends on how your current environment is configured.
This blog post does a great job of explaining what you need to do when using WebGISDR to restore to a new environment. https://www.esri.com/arcgis-blog/products/arcgis-enterprise/administration/migrate-to-a-new-machine-...
I'm not 100% sure on your last question. I want to say that you could use Enterprise/Cloud builder and then do a WebGISDR restore to it. I mean, using those builders shouldn't prevent you from doing a WebGISDR, so I'm thinking it would be fine, but I've also never been in that specific situation before.
Edit: To add on, the WebGISDR is at the software level, not server/cloud level. So I can't imagine there being any issues or gotchas when using WebGISDR to go from AWS to Azure. I'd imagine it would be more configuration related things at the server/cloud level and not the Esri level.
