Map cashing: selecting tilling schema file,
810
02-15-2013 11:22 AM
JamalNUMAN
Legendary Contributor
I???m wondering how the tilling schema file can be changed (another schema file is required to be used as tilling schema file).
The system doesn???t allow selecting the tilling schema file (after a schema file is selected)
[ATTACH=CONFIG]21848[/ATTACH]
How might this issue be resolved?
Thank you
Best
Jamal
Jamal Numan
AnthonyGiles
Frequent Contributor II
Jamal,
You would have to delete the cache then create a new tiling scheme, or you can use the manage map server cache scales tool to add, delete scales, see:
http://resources.arcgis.com/en/help/main/10.1/index.html#//00540000000n000000
Regards
Anthony
AnthonyGiles
Jamal,
Regards
Anthony
JamalNUMAN
Jamal,
Regards
Anthony
Many thanks Anthony for the help. This is very useful
[ATTACH=CONFIG]21884[/ATTACH], [ATTACH=CONFIG]21885[/ATTACH], [ATTACH=CONFIG]21886[/ATTACH]
Best
Jamal
Jamal Numan
