Mandatory acknowledgment of web service terms and conditions
808
05-11-2023 09:13 PM
JustinOdell
Is it possible to apply a mandatory acknowledgement of a web service's 'terms and conditions' (e.g. a caveat)? I understand it is possible to create a GUI in a web-app which the user must acknowledge before proceeding. Can something similar be applied at the web-service level?
I want my users to understand a mandatory note must be applied to any products utilising the available web-service. I can write this into the terms and conditions on the Item Description page; however I need it in the user's face as many users will not read the terms and conditions in great detail.
JohannesLindner
Web AppBuilder: Splash Widget
Experience Builder: Add a window and set it as Splash
Both of these show a splash screen when you start the app. The user has to acknowledge that screen. Optionally, you can add a checkbox to not show this screen again.
Have a great day!
Johannes
A_Wyn_Jones
This must be configured at the application level.
MapServices are usually consumed via JSON/Image Response - the capability of map services to then render an HTML acknowledgement is not currently possible. If you feel this would be a great addition to ArcGIS Server, please use the ArcGIS Ideas page to post your suggestion!
There is the ability to add Document information and Service description which would be present at the map service level, this does not necessarily present itself to the user unless you specifically look for it e.g. https://sampleserver6.arcgisonline.com/arcgis/rest/services/Energy/HSEC/MapServer
Here's some further reading 🙂 https://enterprise.arcgis.com/en/server/latest/publish-services/windows/metadata-for-services.htm
Hope this helps!
"We've boosted the Anti-Mass Spectrometer to 105 percent. Bit of a gamble, but we need the extra resolution."
