I'm trying to list the properties of all the services from GIS Server using python.
Is there any sample script with validating the user and password credentials?
ArcGIS API for Python | ArcGIS for Developers is expressly designed for web-GIS activities, have you looked at the Guide or any Sample Notebooks?
UPDATE: Sample code for listing all services and printing their JSON properties.
from getpass import getpass
from arcgis.gis.server.catalog import ServicesDirectory
url = # GIS server base URL, i.e., https://FQDN:6443/arcgis
user = # admin username
SD = ServicesDirectory(url, username=user, password=getpass(), verify_cert=False)
for dir in [None] + SD.folders:
for srv in SD.list(folder=dir):
print(str(srv.properties))
Hi Manes,
You could try something like below. It will iterate through all the services and print the properties:
import urllib, urllib2, json
# Variables
username = 'siteadmin'
password = 'siteadmin'
server = "gis.esri.com"
tokenURL = 'http://{}:6080/arcgis/tokens/'.format(server)
params = {'f': 'pjson', 'username': username, 'password': password, 'client': 'requestip'}
req = urllib2.Request(tokenURL, urllib.urlencode(params))
response = urllib2.urlopen(req)
data = json.load(response)
token = data['token']
baseUrl = "http://{}:6080/arcgis/admin/services".format(server)
catalog = json.load(urllib2.urlopen(baseUrl + "/" + "?token=" + token + "&f=json"))
print("ROOT")
services = catalog['services']
for service in services:
if service['type']!= 'StreamServer':
print("\t" + str(service['serviceName']))
serviceURL = "{0}/{1}.{2}?token={3}&f=json".format(baseUrl, service['serviceName'], service['type'], token)
serviceProperties = json.load(urllib2.urlopen(serviceURL))
print("\t\t" + str(serviceProperties))
folders = catalog['folders']
for folderName in folders:
if str(folderName) not in ('System', 'Utilities', 'DataStoreCatalogs'):
print(str(folderName))
catalog = json.load(urllib2.urlopen(baseUrl + "/" + folderName + "/" + "?token=" + token + "&f=json"))
serviceURL = "{0}/{1}/{2}.{3}?token={4}&f=json".format(baseUrl, folderName, service['serviceName'], service['type'], token)
Thanks Jake.
Hi Jake.
This code is working with sample arcgis online services and posting the results. When trying with my server's site,it fetches the token and posts
error inline 19: services = catalog['services']
KeyError: 'services'.What cud be the fix!
Under line 18, add the line:
print(catalog)What is returned?
