Listen to any published recently service on ArcGIS Server
1488
13
11-27-2017 11:38 PM
MarkMindlin_idea
New Contributor III
We are thinking what approach could be to handle event of publishing (successfully) a service on ArcGIS Server. Could it be done with a server extension? How?
ArcGIS Server 10.5.1. (No ArcGIS Portal)
Any help please.
MarkMindlin_idea
New Contributor III
We have an error
Should we switch on something on the service?
JonathanQuinn
Esri Notable Contributor
What child resources are available to you from the service information page:
Ex.
I see in your other post, Watch ArcGIS Server directories on a service change , you listed a directory for 10.3.1:
The correct answer (tested on 10.3.1 version) is
arcgisserver\10.3\config-store\services\folderName\<service name>.MapServer\<service name>.MapServer.json
Are you using 10.5.1 or 10.3.1?
MarkMindlin_idea
New Contributor III
We have 10.3.1 working and upgrading to 10.5.1 or 10.6.
I understand its 10.5.1 feature?
JonathanQuinn
This is something we added at 10.5 to support incremental backups, so yes, it won't be available at 10.3.1.  Since you are upgrading to 10.5.x I would wait to implement anything, but that's up to you.
