Is there a way to download web map service published by ArcGIS Server if I connect to it as a user?
16467
24
03-18-2017 11:44 AM
lubnanajeh
Hi All,
I couldn’t figure out if is there a way to download web map service published by ArcGIS Server. Kindly note that I interested to do this in case of I connected to ArcGIS Server as a user not a publisher or admin.
Thanks in advance
Best
Tags (1)
JamalNUMAN
Legendary Contributor
This appears not to work in Pro. The “export feature” option is deemed!
What might be the issue here?
Jamal Numan
KrystinaHartwell1
Add the data from the service on your map and then use the feature class to feature class tool.
JamalNUMAN
Never worked with me
Jamal Numan
KrystinaHartwell1
You have to add the layer from the service to your TOC. The tool should have a drop down to select the layer as an input feature when it has been added to your TOC.
JamalNUMAN
It works like a charm! Thank you KrystinaHartwell1
Jamal Numan
