Dear Geonet Members,
I'm trying to setup ArcGIS Server. There are a number of links under
http://server.arcgis.com/en/server/10.3/install/ but unfortunately
checking each link one by one is not easy.
My question is if there is any available document explaining the steps
to setup ArcGIS Server. It would be great if you could suggest a document
as pdf file or a book, preferably e-book. Thank you
Best Regards
- Omur Saygin,PhD.
Hello Dan,
Thank you for reminding me this important point. I will post a message regarding the sources I found.
Thanks again.
did you mean to mark your question as answered? If so, you might want to share in case others have a similar question.
Hello Dan,
Thanks again.
Dear All,
I have posted a question asking if there is a complete guide to setup ArcGIS Server.
I did quite an extensive search on web but couldn't find a complete guide to setup ArcGIS Server. Afterwards, I carefully checked out the documents prepared by ESRI and finally realized that there wouldn't be a complete guide since setting-up and configuration of ArcGIS changes depending on user requirement and scenario. However, in my case, I find installation guide in Install ArcGIS Server on one machine—Installation Guides (10.4) | ArcGIS for Server is quite helpful. I would also strongly recommend the book titled `Administering ArcGIS for Server` by Nasser Hussein, Pack Publishing (ISBN:9781782177364) .
I hope this would be helpful for everyone who has similar question on the same issue.
I have that book, it is extremely handy. Only one of its kind around. More like this are needed.
