Is SQL Server 2014 compatible with latest release of ArcGIS Server say 10.2
4754
6
01-25-2015 04:57 AM
shafitrumboo
AsrujitSengupta
Regular Contributor III
SQL Server 2014 is now supported with ArcGIS 10.2.1 and 10.2.2
System Requirements
larryzhang
Pls refer to ArcGIS Help (10.2, 10.2.1, and 10.2.2) , which does indicate SQL Server 2014 under 10.2
larryzhang
SQL Server System Requirements
JoshuaBixby
Since the SQL Server 2014 question has been answered, I will just point out the latest release of ArcGIS for Server is 10.3.
larryzhang
it looks that 10.3 still demand SQL Server 2012 or earlier (below).
JoshuaBixby
My guess, that table you reference simply has outdated information.  Do you have a link?
If you look at the ArcGIS for Desktop - Microsoft SQL Server database requirements for ArcGIS 10.3 web page, you will see that SQL Server 2014 is supported.  I thought I came across a similar ArcGIS for Server page, but I can't find it now.  Also, a GeoNet discussion (Microsoft SQL Server 2014 and ArcGIS 10.2.2) from this past November has an Esri staffer commenting that SQL Server 2014 support starts at ArcGIS 10.3.
AsrujitSengupta
System Requirements
