Is it possible to restrict access to layers in a service based on a shape?
1460
7
05-09-2023 06:38 PM
MarkChilcott
Hi All,
Is it possible to restrict access to layers in a service, based on a spatial filter?  Can I define a shape / geometry where only requests that inside the shape will be displayer, identified, and generally returned to the users?
Cheers,
Mark
Scott_Tansley
MVP Regular Contributor
TanuHoque
you can use SOI and map service's clip/spatial filter capabilities to accomplish that.
https://developers.arcgis.com/enterprise-sdk/guide/net/what-is-an-soi-net/
look for clipping and spatialFilters parameters in map service export operation help. https://developers.arcgis.com/rest/services-reference/enterprise/export-map.htm
The same options area available for Identify operation. For query you would need to use geometry parameter.
MarkChilcott
I was hoping it would be a simple solution.  Perhaps a definition query on the shape field with st_geometry?
Scott_Tansley
That would be nice.  🙂
Scott Tansley
https://www.linkedin.com/in/scotttansley/
TanuHoque
you are right, that should just work if your data are in enterprise database. Sorry I was thinking of some complicated workflows.
MarkChilcott
I wonder if I can create a spatial view of the feature class, containing the shape.  Might have to look at that ...
Scott_Tansley
do you need different views for different users/groups?  If so then you'll be looking at a different service for each with the system overheads that can introduce.
Scott Tansley
