I am trying to publish XY event data, either to ArcGIS Server or ArcGIS Online. The data comes from two tables that are joined (one table contains attributes, the other has the XY location data). The XY event layer derived from this works well in ArcMap, but when I try to publish in ArcGIS Server, I get the following message: 001270: Consolidating the data failed
-The data is all in a file GDB which has been registered to the ArcServer.
One more thing, create a new connection to your ArcGIS Server (In ArcMap) using http.
Am assuming your site's protocol is set to both HTTP and HTTPS. Try publishing with the new connection.
Nope, still gives the same error message as earlier.
Hi, it`s works in arcgis 10? it`s posibble to set a No available Connection
