Is it possible in Arcgis server 10.5 to restrict users with Publisher roles to access and publish to specific folders only ?
2641
04-02-2017 04:40 AM
ArwaShaqour
Hi All,
We are trying to restrict users with publisher roles to publish services in their folders such that no user has an editable access to others folder??
I attached Screen Shots that explain the issue.
I would appreciate if anyone can help me ?
best,
Arwa
JayantaPoddar
When a role has its role type set to Administrator or Publisher, members of that role will have implicit permission to access all services hosted on an ArcGIS Server site. This implicit permission cannot be overridden by changing the permissions on a service or folder.
Editing permissions in Manager—ArcGIS Server Administration (Windows) | ArcGIS Enterprise
Think Location
ArwaShaqour
I read about publisher and user roles , I didn't find permissions between publishers.
thanks for your reply.
ScottTansley3
When you're working in an ArcGIS Server and using 'Server Token Security' the level of control is minimal.  You can use it or not, you can publish or not, you can admin or not.  There is no way to control publishing from one folder to another. i.e. if someone has publish rights, they can publish anywhere.
When you're working with ArcGIS Enterprise and using Portal security, then you have more control when publishing Hosted Feature Layers.  However, it still doesn't work with the more traditional type map services associated with a traditional ArcGIS Server, like this.
