Install Python 3.0 packages on ArcGIS Server 10.6.1
584
01-15-2020 02:07 PM
AhjungKim4
Occasional Contributor II
My team is authoring a Pro script tool using 'arcgis' and 'reportlab' modules. I want to publish this as a web tool (geoprocessing service) to ArcGIS Enterprise 10.6.1 for testing, then finally to client's  ArcGIS Enterprise 10.5. I have cloned the env, activated the new env, and finally installed the reportlab package following the documentation here: https://enterprise.arcgis.com/en/server/latest/publish-services/windows/deploying-custom-python-pack... But alas, I later realized it was an instruction for 10.7. Would it still work for my 10.6?
MargaretM
Did you ever get this working? I have a similar issue - trying to deploy a Reportlab script as a Web Tool. It runs in ArcPro in our cloned environment just fine (both locally and directly on server) and packages as a web tool for Portal ok.  But when I try to run the web tool from Portal, it isn't recognizing the reportlab.pdfgen library. I did use Conda to make a clone and installed reportlab into that environment (and activated it) but still no luck. We are running ArcGIS Server 10.6.1 and ArcPro 2.6. Any help is appreciated! Thank you!
SH013
did anyone get this to work? We are also trying to get this work as a web took but having issues setting this up on the server.
