I'm trying to publish a feature server, and get "Invalid folder location", even though Server Manager validates the folder is accessible.
2071
03-22-2016 04:20 PM
ChuckBenton
Here's the error, which is generated when attempting to register the folder using ArcMap Basic.  Note the Server is Standard.
Here's the result I get from Server Manager for the exact same folder:
I've made sure the folder is shared.
Any ideas on what I'm missing?  FYI, I'm following the procedures outlined in the Tax Parcel Viewer sample.
Chuck
Tags (3)
ChuckBenton
I just spent over a week trying to get this running, not realizing that I could not use a folder based data store when publishing a feature service under ArcGIS for Server (as opposed to ArcGIS Online).  Per the Server analyst that assisted me: "No, I would not have done it the same way since publishing a feature service requires that it resides in a multiuser geodatabase (SQL Server, Postgres, Oracle, etc.).  The AWS instance should come with an install of SQL Server or SQL Server Express.  You will need to move your data into a multiuser geodatabase that is registered with server or the SQL Server instance that comes with AWS (not a folder) and then re-publish.  Alternatively, you can publish data in a folder or file geodatabase to ArcGIS Online and create a feature service without any additional steps."
It would have been nice if the guidance in the sample had made that clear... well, live and learn...
