i am un able to know what is error in this code....the result is not shown when the code is run..
3542
04-27-2015 03:43 AM
aneeshasatya
<%--<%@ Page Language="C#" AutoEventWireup="true" CodeBehind="population.aspx.cs" Inherits="WebApplication3._Default" %>--%>
<!DOCTYPEhtml>
  <html>
  <head>
    <metahttp-equiv="Content-Type"content="text/html; charset=utf-8">
    <!--The viewport meta tag is used to improve the presentation and behavior of the samples
      on iOS devices-->
    <metaname="viewport"content="initial-scale=1, maximum-scale=1,user-scalable=no">
<title>Nalgonda point data popup</title>
        <linkrel="stylesheet"href="http://js.arcgis.com/3.13/dijit/themes/claro/claro.css">
        <linkrel="stylesheet"href="http://js.arcgis.com/3.13/esri/css/esri.css">
<style>
            html, body,
            #map
            .map.container {
            padding: 0;
            margin: 0;
            height:50%;
      #info {
         top: 2px;
         color: #444;
         height: auto;
         font-family: arial;
         font-weight: bold;
         left: 69px;
         margin: 5px;
         padding: 10px;
         position: absolute;
         width: 260px;
         z-index: 40;
         border: solid 1px #003300;
         border-radius: 4px;
         background-color: Green;
        /* Change color of icons to match bar chart and selection symbol */
            .esriPopup.darkdiv.titleButton,
            .esriPopup.darkdiv.titlePane.title,
            .esriPopup.darkdiv.actionsPane.action {
            color: #A4CE67;
        /* Additional customizations */
            .esriPopup.dark.esriPopupWrapper {
            border: none;
            .esriPopup.contentPane {
            text-align: center;
            .esriViewPopup.gallery {
            margin:0auto;
</style>
        <script src="http://js.arcgis.com/3.13/"></script>
<script>
    var map;
    require([
        "esri/map",
        "esri/dijit/Popup", "esri/dijit/PopupTemplate",
        "esri/layers/FeatureLayer",
        "esri/symbols/SimpleFillSymbol", "esri/Color",
        "dojo/dom-class", "dojo/dom-construct", "dojo/on",
        "dojox/charting/Chart", "dojox/charting/themes/Dollar", "dojo/parser",
        "dijit/layout/BorderContainer", "dijit/layout/ContentPane", "dijit/TitlePane",
        "dojo/domReady!"
             ], function (
        Map,
        Popup, PopupTemplate,
        FeatureLayer, SimpleFillSymbol, Color, BasemapGallery, arcgisUtils,
        domClass, domConstruct, on,
       Chart, Dollar, parser) {
          parser.parse();
          map = new Map("map", {
              basemap: "topo",
              center: [78.8718, 21.7679],
              zoom: 4
          //add the basemap gallery, in this case we'll display maps from ArcGIS.com including bing maps
          var basemapGallery = new BasemapGallery({
              showArcGISBasemaps: true,
              map: map
          }, "basemapGallery");
          basemapGallery.startup();
          basemapGallery.on("error", function (msg) {
              console.log("basemap gallery error:  ", msg);
          //The popup is the default info window so you only need to create the popup and
          //assign it to the map if you want to change default properties. Here we are
          //noting that the specified title content should display in the header bar
          //and providing our own selection symbol for polygons.
          var fill = new SimpleFillSymbol("solid", null, new Color("#A4CE67"));
          var popup = new Popup({
              fillSymbol: fill,
              titleInBody: false
          }, domConstruct.create("div"));
          //Add the dark theme which is customized further in the <style> tag at the top of this page
          domClass.add(popup.domNode, "dark");
          map.infoWindow = popup;
          //          map = new Map("map", {
          //              basemap: "gray",
          //              center: [78.8718, 21.7679],
          //              zoom: 4,
          //              infoWindow: popup
          var template = new PopupTemplate({
              title: "munugode subdivision",
              description: "{village}:  {population} are affected",
              fieldInfos: [{ //define field infos so we can specify an alias
                  fieldName: "Number_Ent",
                  label: "Entrants"
                  fieldName: "Number_Sta",
                  label: "Starters"
                  fieldName: "Number_Fin",
                  label: "Finishers"
              mediaInfos: [{ //define the bar chart
                  caption: "",
                  type: "barchart",
                  value: {
                      theme: "Dollar",
                      fields: ["Number_Ent", "Number_Sta", "Number_Fin"]
          var featureLayer = new FeatureLayer("http://3092-ggngis:6080/arcgis/rest/services/BSESWithoutOwnership/FeatureServer/0", {
              mode: FeatureLayer.MODE_ONDEMAND,
              outFields: ["*"],
              infoTemplate: template
          map.addLayer(featureLayer);
</script>
</head>
<body  class="claro">
            <div data-dojo-type="dijit/layout/BorderContainer"
            data-dojo-props="design:'headline', gutters:false"
            style="width:75%;height:75%;margin:0;">
    <div id="map"
            data-dojo-type="dijit/layout/ContentPane"
            data-dojo-props="region:'center'"
            style="padding:0;">
    <div style="position:absolute; right:20px; top:10px; z-Index:999;">
    <div data-dojo-type="dijit/TitlePane"
            data-dojo-props="title:'Switch Basemap', closable:false, open:false">
            <div data-dojo-type="dijit/layout/ContentPane"style="width:100; height:100px; overflow:auto;">
            <divid="basemapGallery"></div>
</div>
</div>
</div>
</div>
</div>
</body>
</html>
VinceAngelo
Esri Esteemed Contributor
Above and beyond the fact that this is a "wall of code" post (which historically have low response rates), you've likely posted it in the wrong group (if this is a JSAPI question, it belongs over in ArcGIS API for JavaScript).
Please edit this question to contain a complete description of what you are trying to accomplish, and what this code actually does.  Also appropriate:
  • The version of ArcGIS Server in use
  • The properties of the BSESWithoutOwnership service
  • The origin of the bulk of this code
If you need to move this post, you can do so through the "Actions" menu on the upper right side.
- V
VinceAngelo
- V
RebeccaStrauch__GISP
I'm on my iPad, so haven't looked thru full code, but it looks like you are missing reference to
In require section.
