How to switch all services from “Dedicated” to “Shared” in one go?
1972
10-04-2019 02:16 AM
JamalNUMAN
Legendary Contributor
I couldn’t figure out how to switch all services from “Dedicated” to “Shared” in one go
Jamal Numan
JonathanQuinn
Esri Notable Contributor
Any request to the Admin API can be scripted. If there isn't a built-in function within the Python API, watch the network traffic using Fiddler or your browsers dev tools and re-create the request yourself:
import urllib
import urllib2
import json
import traceback
import ssl
base_url = 'https://machine.domain.com:6443/arcgis'
username = 'admin'
password = 'admin'
service = "<service name>"
#Function to open URLs
def openUrl(url,params):
    try:
        if not params:
            params = {"f":"json"}
        else:
            params.update({"f":"json"})
        encoded_params = str.encode(urllib.urlencode(params))
        request = urllib2.Request(url)
        sslContext = ssl._create_unverified_context()
        request.add_header('referer',base_url)
        response = urllib2.urlopen(request,encoded_params, context=sslContext)
        decodedResponse = response.read().decode('utf-8')
        jsonResponse = json.loads(decodedResponse)
        return jsonResponse
    except Exception as e:
        raise Exception("Unable to open {} - {}".format(url,e))
#Get a token
token_params = dict(username=username,
                    password=password,
                    client='referer',
                    referer=base_url)
token_url = '{}/tokens/generateToken'.format(base_url)
token = openUrl(token_url,token_params)['token']
#Change provider from ArcObjects11 to DMaps
changeProviderURL = '{}/admin/services/{}.MapServer/changeProvider'.format(base_url,service)
changeProviderParams = dict(provider="DMaps",
                            token=token)
updateProviderResp = openUrl(changeProviderURL,changeProviderParams)
if "status" in updateProviderResp and updateProviderResp['status'] == "success":
    print("Successfully updated {} to be shared".format(service))
else:
    print("Unable to update {} to be shared - {}".format(service,updateProviderResp['messages']))
In order to do all services, you'll need to make requests to the root folder to find all services and then loop through them, and then loop through all folders. Each loop, you'd pass in the service name instead of hard coding it.
George_Thompson
I am not sure that we have a default way to change all the services to the shared pool. It "may" be able to be done via scripting (ArcPy and/or API). Configure service instance settings—ArcGIS Server Administration (Windows) | ArcGIS Enterprise
--- George T.
JonathanQuinn
import urllib
import urllib2
import json
import traceback
import ssl
username = 'admin'
password = 'admin'
    try:
        if not params:
        else:
        return jsonResponse
#Get a token
                    password=password,
                    client='referer',
                    referer=base_url)
                            token=token)
else:
MoginrajMohandas
Pls also refer to the following blog that shares a sample of how to iterate through services and bulk move services from Dedicatd to Shared instances. Move services to shared instances using Python
