How to restrict access to portal home directory to certain IPs?
513
03-07-2022 10:58 AM
MichaelGinzburg
Hello,
How can I restrict access to portal home directory https://XXX/portal/home to certain IPs?
Thanks!
Scott_Tansley
MVP Regular Contributor
Theoretically, you can do this in IIS if you’re using the IIS Web Adaptor?  What do use above the Portal?
Scott Tansley
https://www.linkedin.com/in/scotttansley/
