How to publish a service from ArcGIS Pro to ArcGIS server?
41027
68
11-26-2014 01:10 PM
GabrielYarlequé
I am trying to figure out how to publish a service to ArcGIS Server directly from ArcGIS Pro. I found out how to make the connection to the server and how to share my map as a webmap. So now I want to know if there is a way to publish the same map via ArcGIS Server.
Thanks a lot for your help!
ThomasColson
MVP Frequent Contributor
Don't forget to upvote https://community.esri.com/ideas/12258
TanuHoque
nicogis
JamalNUMAN
Legendary Contributor
Simple, We need to publish as we do currently in ArcMap. This is not available in 2.3
Jamal Numan
TanuHoque
the UI experience is not in there in Pro 2.3, but you can use arcpy functions to do that as stated by Domenico Ciavarella‌ - just make sure when you create .ags file (arcgis server connection) you pick the option to store user/pwd with the connection file.
In Pro 2.4, we have a plan to publish services from Pro to standalone-server using UI (without any arcpy script).
JamalNUMAN
This has been totally resolved in 2.4 release:
ArcGIS Pro 2.3: Are we going to publish directly to ArcGIS Server in Pro 2.3 without the need to hav...
Jamal Numan
SandeepBurra4
New Contributor II
This issue is addressed: Publish a map service—ArcGIS Pro | ArcGIS Desktop
This workflow is only available when publishing to stand-alone ArcGIS Servers.
JamalNUMAN
Thanks. Implemented in 2.4 as per screenshots below
Jamal Numan
HeatherHerrmann2
I know this was 7 months ago but thank you so much for this!  Super helful!
