How to install two web adaptors on the same machine ?
1690
07-04-2018 08:20 AM
SaraEL_MALKI
Occasional Contributor II
Hello there,
I'm using 10.5.1 version
I've installed wa for arcgis server and named it "server"
but I can't install another WA for my Portal, because the setup.exe gives me only two options "repair" or "Remove"
I tried to follow the instructions in this response :
How to set up two Web Adaptors on one machine (for AG Server and Portal)
but I get the error:
Application Error: Access to the path 'C:\Inetpub\wwwroot\arcgis\WebAdaptor.config' is denied
I've tried the solution suggested here :
Error: Application Error: Access to the path 'C:\Inetpub\wwwroot\arcgis\WebAdaptor.config' is denied
but in the step number 9 in the link above, I can't enter enter 'IIS APPPOOL\ArcGISWebAdaptorAppPool' user,
so I am literally BLOCKED
please guys help me,
and tag anyone that has already faced the same problem ..
my Best regards
SaraEL_MALKI
FINALLY I solved that problem,
 actually when I wasn't able to add the IIS APPPOOL/ArcGISWebAdaptorAppPool v4.0 user to my webAdaptor file, I changed the owner of the file from "administrator" to "system" then simply added the user "everyone" as a user of the file and give it full control over it and that solved my problem, so the instructions are:
1. Install your 1st web adaptor, and you name it 'waportal' > don't register anything in here
2. go to c:/inetpub/wwwroot -> copy 'waportal' and paste on the same place c:/inetpub/wwroot/
    by default second wa name is 'waportal copy'. rename it, for example 'waserver'
3. you have to convert 'waserver' as application. go to IIS Manager > in the left side expand Default Website > right click in waserver, choose convert to application
4. chnage the owner of the file webadaptor.config from administrator to "system" and then try to add the user "IIS APPPOOL/ArcGISWebAdaptorAppPool " and give it full control, if that doesn't work, add instead "everyone" user.
5. you have 2 wa right now. the first is waportal and the second is waserver.
a. register your portal on your waportal
go to http://yourhost/waportal/webadaptor/ > select portal for arcgis then follow the instruction
b. register your arcgis server on your waserver
go to http://yourhost/waserver/webadaptor/ > select arcgis for server then follow the instruction.
ThomasColson
MVP Frequent Contributor
A few more details would help, such as OS, web server version (IIS? Apache?), etc...but I think you're going to get a quicker answer from TS.
JonathanQuinn
Esri Notable Contributor
Is the IIS_IUSRS group listed as having permissions? Are you installing the WA as an administrator on the machine?
SaraEL_MALKI
HassanMahmoud1
Same Problem with 107
