How to fix the checkerboard pattern in Mosaic Datasets
9663
02-03-2016 07:25 AM
ChadKopplin
Occasional Contributor III
Good morning GeoNet, over  the past couple of weeks we have been fighting a checkerboard when zooming into our Mosaic Datasets.  This comes after our production server and storage drives were moved to a new environment.  I knew that the services were having a problem getting to raster folder to access the images.  After working with Esri Support the fix was easy.  First our problem was that the server names changed along with the IP.  The fix is to repair the path to the images on each Mosaic Dataset that you have.  Here is the procedure:
1.  Open ArcCatalog
2.  Connect to your Geodatabase
3.  Right click on the Mosaic Dataset
4.  Click on Modify>Repair
The process will spool through the service then get to the Repair Dataset Dialogue box.  Here the user is able to put in the new path and choose to click OK or click in the Only Broken Link box (the repair is taking place at this time).  In many cases this should fix the issue, but in some cases the rasters may reside on a storage drive, and the drive maybe shared with everyone to gain access to the base images.  The problem that we encountered was that once the servers were moved it broke the share on the raster folder housing the base images.  In this case have the server administrator go onto the server and re add the ArcGIS server account as a user on the GIS server, and give the account permission to access the share and remake the share on the server.  This should fix the other people that still are not able to view the images after first running the repair.
Are these the only ways of fixing this issue that others may have run into?  Please give other fixes that you may have run into to get around this issue.  Thank you.
One last item of interest, the repair requires either an Advance or Standard license.
Message was edited by: Chad Kopplin
DerekLaw
Esri Esteemed Contributor
Hi Chad,
Just FYI, there's an older blog post that discusses this topic:
Does your mosaic dataset look like a checkerboard? | ArcGIS Blog
Hope this helps,
ChadKopplin
Thanks Derek, Here is the link to the fix from that blog.
Are there broken paths in your mosaic dataset? | ArcGIS Blog
I did have a couple of other issues that I wanted to share with everyone.  My 24k EDRG mosaic would not finish, it would only repair about half of the links.  I went in to the Admin for the geodatabase in ArcCatalog and I removed the locks on the geodatabase, then I went in to run the repair and this allowed me to fix the remain links.  The second issue is that when the server name changed, I need to recreate our Image Server Services for these mosaic datasets, because the Image Server Services are tied to the Server Name, just an FYI if anyone runs into the same issues.  Thank you.
MichaelVolz
When I create an RMD I used a mapped network drive to add the images.  I also used a mapped network drive to point to the overviews.  Now when I navigated to the RMD in ArcCatalog I used a unc path and the image service was published successfully (no error messages), but I get a checkerboard pattern.  When I look in AGS Manager, I see warnings that there are missing rasters.  Even though I do not receive error messages during publishing, should I resource the raw imagery and overviews with the unc path to these files instead of the mapped network drive to fix this issue?
MelissaWalker
New Contributor II
The link for how to fix is now expired and redirects to the arcgis blog overview page so this is no longer helpful...
