How best to serve a tile cache in ArcGIS Server 10.1
845
06-03-2013 05:46 PM
MarkChilcott
We have a raster dataset, which is a mosaic of our orthophoto state coverage.  We want to serve this via ArcGIS Server, as a base layer for viewing.
I can use the Tile Cache toolset, specifically the Manage Tile Cache tool to create a tile cache:
Manage Tile Cache (Data Management)
http://resources.arcgis.com/en/help/main/10.1/index.html#/Manage_Tile_Cache/001700000189000000/
The question then is, how is this best served via ArcGIS Server?
I can serve the tile cache as an image service.  If I do this, and want it to be really fast, then I could generate an image server cache from the tile cache.  But it does not seem logical to generate a cache of a cache, and it doubles the amount of data we have.
I can place the tile cache in a map document as a raster data source, and then serve the map document.  But again, to make it fast, I can generate a map server cache.  But again, I have a cache of a cache and it double the amount of data we have.
With a bit to stuffing around, I can create an image service, with an image server cache.  I can then replace that image service, where the data source reference the actual cache.  The source of the image service becomes the image server cache.
I can do a similar thing with respect to a map service, where the data source in the map document, is the actual map services own cache.
I am still left with the question of should I do this, and also, should I do it with a map service or an image service?
The data source has to be a raster, so that I can have the WMS capability.
Cheers,
Mark
