HA Portal Logs
840
07-31-2023 09:26 PM
WengNg4
In a scenario where ArcGIS Portal was deployed in HA with an external ELB and assuming that both machines were named:
  • Machine A (Primary)
  • Machine B (Standby)
When I query Portal logs from the REST endpoint, why does it show entries for both Machine A and Machine B executing user actions like when users publish a service despite Machine A acting as the primary. Shouldn't only Machine A do the bulk of the work?
Is this a normal behavior or has it got something to do with the ELB routing to the standby machine instead?
I understand both machines are capable of processing requests and acts as if they're active-active in HA --->Re: Activ-Activ "Portal for ArcGIS" in HA deployme... - Esri Community
A_Wyn_Jones
@WengNg4
Portal HA is active-active (as mentioned in the linked post), the underlying database of Portal for ArcGIS will create a new item in the database of Machine A and Machine B when a user publishes an item to Portal.
This is to ensure the requests can be fulfilled on both machines regardless of where the ELB directs the request.
"We've boosted the Anti-Mass Spectrometer to 105 percent. Bit of a gamble, but we need the extra resolution."
A_Wyn_Jones
@WengNg4
