group managed service account for arcgis server
4549
13
02-22-2024 12:48 PM
ShirleyYueLi
I'm configuring arcgis server to run on a group managed serviced account. I used the ServerConfigurationUtility command line tool according to this documentation https://enterprise.arcgis.com/en/server/latest/administer/windows/the-arcgis-server-account.htm and it says a password is not needed. However, I got an error 'Invalid password specified for (the group managed service account)'. Our IT told me the group managed service account doesn't have a password. They have also granted the account 'log on as a service' permission. I also tried to change the 'Log On as' for the arcgis server service to this account but the service would not start. How can I configure arcgis server to use a group managed service account? Thank you!
Scott_Tansley
MVP Regular Contributor
If the server (host machine) is registered by your SAs in the gMSA then it will just work.  There is no configuration on the ArcGIS Server side.  It's simply just a case of entering the gMSA account details as stated.  All the configuration is completed by your sys admins.
If the command line is not working for you then try the GUI approach described here:  https://enterprise.arcgis.com/en/server/latest/get-started/windows/what-s-included-with-arcgis-serve...
Scott Tansley
https://www.linkedin.com/in/scotttansley/
MarceloMarques
ArcGIS Server account—ArcGIS Server | Documentation for ArcGIS Enterprise
ServerConfigurationUtility.exe /username mydomain\enterprise-gmsa$ /writeconfig c:\temp\domainaccountconfig.xml
| Marcelo Marques | Esri Principal Product Engineer | Cloud & Database Administrator | OCP - Oracle Database Certified Professional | "About: In 1992, I embarked on my journey with Esri Technology, and since 1997, I have been working with ArcSDE Geodatabases, right from its initial release. Over the past 33 years, my passion for Spatial Databases and GIS data has become a central part of my career.." | “ The mountains are calling and I must go.” – John Muir |
ShirleyYueLi
Thank you! I used the configure arcgis server account GUI and command line tool but both got an error: no password specified. Is a password required? Our IT told me there is no password for this gmsa account. What should I ask our IT for?
ShirleyYueLi
Thank you! I used the configure arcgis server account GUI and command line tool but both got an error: no password specified. Our IT told me there is no password for this gmsa account. What configurations should sys admins do? Thank you!
BillFox
MVP Notable Contributor
can you share the info Scott and Marcelo provided directory to your IT team?
MarceloMarques
ShirleyYueLi
I used this command ServerConfigurationUtility.exe /username mydomain\enterprise-gmsa$ /writeconfig c:\temp\domainaccountconfig.xml but got an error "invalid password specified for ..." Is there any configuration we missed for this account? IT has granted 'log on as service' permission for this account.
BillFox
MarceloMarques
@ShirleyYueLi - your gMSA domain account might not have been configured correctly.
Getting Started with Group Managed Service Accounts | Microsoft Learn
