Fail to create replica.Multiple layers are referencing a dataset,which is not support
7730
05-08-2014 11:14 PM
RajasekarNammalvar
As per the following documentation, we have enabled the sync capability for feature service.
http://resources.arcgis.com/en/help/main/10.2/index.html#//0154000006m1000000
We can see all the layers in the feature service & it's sync capabilities informations,
Sync Capabilities:
[INDENT]Supports Registering Existing Data: true
Supports Sync Direction Control: true
Supports PerLayer Sync: true
Supports PerReplica Sync: false
Supports RollbackOnFailure : false
Supports Async: true[/INDENT]
And we are trying to access the feature service from the client application (Android device) & got the following error,
[INDENT]"Failed to create replica. Multiple layers are referencing a dataset, which is not supported."[/INDENT]
we have did some workaround to resolve this issue. But it's always throwing the same exception. We were not sure about this issue. If any help that would be appreciated.
NicolasGIS
Might be a bit late, but I had the same problem.
I think this problem might come from the fact that you have several layers referencing the same feature class.
For me, I solved the problem by creating only one layer referencing this feature class with a symbology by category instead. But be careful, I noticed that the "unique values, may fields" is not supported.
Hope it will help.
MatthewFletcher
I encountered the same error when downloading data onto the Collector app.  The "several layers referencing the same feature class" solution worked for me, thanks Nicolas!
