Export of Portal repository fails due to missing item folder
4882
13
06-12-2019 04:26 PM
EricJackson1
We are seeing this error in our DR Tool backup log.
2019-06-11 20:30:35 ERROR [pool-2-thread-1] com.esri.arcgis.webgis.component.Portal - {"error":{"code":500,"details":null,"message":"Failed to export site. Export of the Portal repository failed. D:\\arcgisportal\\content\\items\\0b2ddccc355247f09bdac514024e9244"}}
The Portal \Content\items folder is indeed missing this folder.
I manually created a folder with the referenced GUID and the Site Export succeeds.
Will we have a problem if we ever try to restore from this site export?  Does it make sense that a single missing item folder would break the export?
JaredYost3
\\my.share.directory\\fileshare01\\arcgisportal\\content
JaredYost3
Path to where content actually resides C:\arcgisportal\content\items
ErnaldoLumbantobing
Hi All,
I have the same issue on ArcGIS Portal 10.6.1, however the folder it says doesn't exist,
/home/gis/arcgis/portal/usr/arcgisportal/content/items/0bc97df7f18945d19d3224e6be3b1ec1  is not the sub directory of the directory. This ArcGIS running on Linux. Need your help guys, thank you
JonathanQuinn
Esri Notable Contributor
Create the 0bc97df7f18945d19d3224e6be3b1ec1 folder within the /home/gis/arcgis/portal/usr/arcgisportal/content/items directory and the export will go through. Do this for any folder that fails.
