Export Features stacks all points on top of each other (v 3.4.0)
3361
12
12-02-2024 07:13 AM
JasonWeis_Westwood
After updating ArcGIS Pro to version 3.4.0, when I attempt to export a selection of points collected with Field Maps to a file geodatabase feature class, all of the exported points show up in a single location (the location of one of the selected points).  This occurs with both a right-click on the layer name (with Data: Export Features), and also with starting directly from the Export Features geoprocessing tool. The other attributes appear to maintain their original values - it is simply the location that gets modified.
I have been using this workflow frequently in the past (exporting a subset of collected points to a project-specific geodatabase), and the points always exported to the correct locations, even if specifying a new coordinate system. I did not notice this "consolidation" until last week, which just happened to coincide with my v3.4.0 update. (I did clear my display cache as a preliminary troubleshooting step.)
When I tested this with other point data that was NOT populated using Field Maps, the points exported correctly. Likewise, when exporting selected points from a local source (file geodatabase), the points also exported correctly.
I attempted this on a workstation that was still running version 3.3.1, and the points exported correctly, so it appears to be related to version 3.4.0. Has anyone else encountered this issue?
DanielleSchaffeld5
Me too! I "solved" it by using the Feature Class to Geodatabase tool instead. All points and associated attachments were retrieved from the hosted feature layer correctly.
MattAnderson4
This wrecked a set of models that I use all the time. I would like the attachments to work also. Thanks!
JasonWeis_Westwood
I was hopeful that one of the two patches that became available last week would fix this issue. However, after applying both patches (currently at v. 3.4.2), the issue persists.
