Esri portal on apigee?
828
08-28-2019 02:18 PM
SteveMiller4
Would it be possible to expose an internal Esri portal on apigee API manager? If so, will an endpoint only need to be made for the portal, or for each individual layer service we plan to use? On our first attempt we weren't able to due to the way the portal does re-directs during logins. Please let me know if there is a better way to go about it.
SudhirPonnappan1
Steve, I am curious to know if you were able to find a solution or viable approach. We are attempting to expose our ArcGIS REST Service endpoints via Apigee. The server is federated with a portal that is internal to the organization. Portal is configured with Okta to be the identity provider (SAML).
Can you please provide details on your implementation?
