Error loading features in Pro: Failed to add data error
1582
02-14-2021 11:59 AM
JoelKyereNNimarko
New Contributor II
I am trying to load feature class or layers from enterprise with ArcGIS Pro and I keep getting an error that "Failed to add data". enterror.PNG
Please solution to go about this challenge??
by Anonymous User
Not applicable
Hi Joel,
Can you log onto Server Manager and make sure that the service is running? It may be helpful to restart the service just in case. Then, you can try opening the service in a default ArcGIS Online map viewer application as a quick test.
-Calvin
by Anonymous User
Not applicable
Hi Joel,
-Calvin
JoelKyereNNimarko
New Contributor II
Yes Calvin, thanks very much
I restarted the service and restarted the Server itself and it worked
