Error accessing target_cache_path when Importing Map Server Cache
478
01-10-2019 09:56 AM
MartinSirkovsky1
Hi.
I got the following errors, when trying to copy cache to ArcGIS Server map service:
and after running:
I have tried everything but nothing helps. The strange thing is that it used to work, but after we have updated from ArcGIS Server 10.5. to 10.61, it doesn't work. I set a permission to the folders for ArcGIS server user, I even tried to copy the cache I want to import to ArcGIS server cache directory, but to no avail.
Did anybody experienced this issue? ESRI do you have an idea what might be wrong or what to check?
DanGriffin
Same issue here. This use to work in 10.5.1 but no longer works after upgrading.
