When i Analyze my map to publish the warning appeared:
"10030 Layer's data source is ArcSDE not accessed via a direct connection <Data Base> Layer Layers"
i use
oracle11gv2
ArcSDE
Arcgis server 10.1
Arcgis Desctop 10.1
I cannot make direct connection to oracle database from ArcCatalog. I try this syntax's
"sde : oracle11g:/;ORACLE_SID=<SQL_Net_alias>" but it does't work .....
