Embedded dashboard in enterprise site requires two logins - Invalid 'X-Frame-Options'
1346
6
07-11-2019 08:32 AM
FredSpataro
Hi All,
I'm building out a bunch of Enterprise Site pages that have an embedded Ops-Dashboards.  When we access the site page, we are prompted to login to the site (expected and good) and then login again to the dashboard - not excepted and not good.  And even when the site page opens again in a new tab, the site has a cached login and opens the page without the login prompt but still prompts for the login on the dashboard. This seems like a bad workflow and users are definitely not going to like it.  Is there a bug?  Is there specific way to embedded secure content into the site page so it doesn't require two logins?
Setup:
  • Version 10.7
  • Separate portal/server and web-adapter machines
  • Site and dashboard are on the same portal:
  • Chrome/Edge/Firefox all display the same behavior.
    • Invalid 'X-Frame-Options' header encountered when loading ... 'ALLOW-FROM https://server' is not a recognized directive. The header will be ignored.
Seems similar to this: https://community.esri.com/thread/87825 and could be that there's a new header requirement: https://stackoverflow.com/questions/30731290/how-to-set-x-frame-options-allow-from-in-nginx-correctl...
thanks
Fred
by Anonymous User
Not applicable
Hey Fred Spataro did you have any luck with this? I am having the same issue.
FredSpataro
Hi Cameron,
I was not able to solve this one.  We ran into a few more issues with OpsDashboard and decided to go with a custom dashboard instead. Sorry I can't be more help.
Fred
by Anonymous User
Not applicable
Thanks Fred, I'll let you know if I find a solution.
parksh
Hello Cameron,
I have a same question with you.
Did you find any solutions?
Su-hyeon.
by Anonymous User
Not applicable
Unfortaunately not yet @parksh will undate here if i do!
ChrisRoth
I am having the same issue with a customer site. Embedded dashboards in a dashboard all require logging in over and over...
