I have a feature layer with features that I would like to update programmatically. Below is my code:
private void EditQueryTask_ExecuteCompleted(object sender, ESRI.ArcGIS.Client.Tasks.QueryEventArgs args)
try
if (txtServiceType.Text.Contains("Water") || txtServiceType.Text.Contains("WATER"))
FeatureLayer fl = MyMap.Layers["Meters"] as FeatureLayer;
List<int> deletedServiceOrders = new List<int>();
FeatureSet fs = args.FeatureSet;
fs.Features[0].Attributes["PWSID"] = txtMeterNumber.Text;
fs.Features[0].Attributes["CIS_METR"] = txtAccountNumber.Text;
fs.Features[0].Attributes["CUSTYPE"] = txtCustType.Text;
fs.Features[0].Attributes["STR"] = txtStreet.Text;
fs.Features[0].Attributes["CITY"] = txtCity.Text;
fs.Features[0].Attributes["COMMENTS"] = txtName.Text;
fl.SaveEdits();
fl.Update();
DeleteServiceOrder.Visibility = Visibility.Collapsed;
fl.EndSaveEdits += featurelayerSO_EndSaveEdits;
fl.SaveEditsFailed += featurelayerSO_SaveEditsFailed;
catch (Exception e)
MessageBox.Show(e.Message);
Everything is being set correctly and there are no errors, but the values are not actually being saved into ESRI. I am thinking it has something to do with nothing has ever actually be edited? I know I am missing something. Any help would be appreciated!
I suggest taking a look at the Dev Summit examples: http://www.arcgis.com/home/item.html?id=3f69c79bbd7340b09fad396647a977a5
Specifically the Editing-Stand-Alone-Tables example.
Cheers
Mike
Hi Jessica,
If your feature layer is being hosted with Feature Access on ArcGIS Server, you could try something like this:
try
var myServiceUrl = ""; // Enter your service URL here (Ex: http://myAGS:6080/arcgis/rest/services/myService/FeatureServer/ )
var featureString = String.Format(
"[{{\"id\":0, \"updates\": [{{" +
"\"geometry\":{{\"x\":{0},\"y\":{1}}}," +
"\"attributes\":" +
"\"PWSID\":{2}," +
"\"CIS_METR\":{3}," +
"\"CUSTYPE\":{4}," +
"\"STR\":{5}," +
"\"CITY\":{6}," +
"\"COMMENTS\":{7}," +
fs.Features[0].geometry.X,
fs.Features[0].geometry.Y,
txtMeterNumber.Text,
txtAccountNumber.Text,
txtCustType.Text,
txtStreet.Text,
txtCity.Text,
txtName.Text
var parameters = "edits=" + HttpUtility.UrlEncode(featureString) + "&f=pjson";
var wc = new WebClient();
wc.headers["Content-Type"] = "application/x-www-form-urlencoded";
wc.Encoding = Encoding.UTF8;
wc.UploadStringCompleted += (sender, e) =>
if (e.Error == null)
var responseString = e.Result;
if (responseString.contains("\"success\": true"))
MessageBox.Show("Successfully updated.");
else
MessageBox.Show("ERROR: " + responseString);
else
MessageBox.Show("ERROR: " + e.Error.Message);
wc.UploadStringAsync(new Uri(myServiceUrl + "/applyEdits"), "POST", parameters);
catch (Exception e)
The code will probably need some tweaking to fit your needs, but this is roughly what I've been using to update features programmatically.
