Edit Roles and Privileges - Portal
662
10-15-2019 05:55 PM
SoratoSouza_e_Silva
Occasional Contributor II
In the link below, there are some assignments for user viewer, publisher and administrator
Roles and privileges—Portal for ArcGIS | ArcGIS Enterprise
Can I have one role, for example Viewer with all privileges from disable? In the other words a Viewer that can´t do anything?
Thank´s
TrevorNickolai
Hey Andre,
With the default Viewer role, you wouldn't be able to edit this role, but, with a custom role you could build a role that has very very limited functionality.  I tested a custom role with no options enabled, and it purely appears to be a Viewer type role.  It doesn't appear I can create or utilize anything.
DennisSmith
Hello there Andre,
What exactly are you looking to accomplish with this role that you are asking about? Just trying to determine how to best address this.
