Duplicate Field in Service Definition
7818
16
05-17-2013 09:07 AM
DavidMajor
I've added a field to a feature class in my SDE database, then republished the map service using it. The application I use to view the map service now crashes. Its called Cityview. It complains when it crashes that the new field is already in the service. So when I browse to the service, I noticed that the new field I added is displayed twice in the contents of the field definition. I suspect this is the problem but I can't fix it.
I've tried deleting the field, then adding another different field and same thing. Any help would be appreciated.
- David
Using ArcGIS Server 10.1 with SQL SDE and Windows Server 2008 R2
Here is the layer definition:
Layer: Parcels (ID: 17)
Display Field: PID
Type:  Feature Layer
Geometry Type: esriGeometryPolygon
Description:
Definition Expression:
Copyright Text:
Default Visibility: true
MaxRecordCount:  1000
Supported Query Formats:  JSON, AMF
Min Scale:  0
Max Scale:  0
Supports Advanced Queries:  true
Supports Statistics:  true
Has Labels:  false
Can Modify Layer:  false
Can Scale Symbols:  false
Extent: XMin: -1.3333465240339989E7
YMin: 6517317.380403321
XMax: -1.2955377341100832E7
YMax: 6838924.548245557
Spatial Reference: 102100  (3857)
Drawing Info:  Renderer:  Simple Renderer:
Symbol:  Style:  esriSFSSolid
Color:  [0, 0, 0, 0]
Outline:  Style:  esriSLSSolid
Color:  [157, 149, 142, 255]
Width:  1 Label:
Description:  Transparency:  0
Labeling Info:
HasZ: false
HasM: false
Has Attachments:  false
HTML Popup Type:  esriServerHTMLPopupTypeAsHTMLText
Type ID Field:  null
Fields:  ??? OBJECTID  ( type: esriFieldTypeOID , alias: OBJECTID )
??? ROLL  ( type: esriFieldTypeDouble , alias: ROLL )
??? IDPARCEL  ( type: esriFieldTypeString , alias: IDPARCEL , length: 8 )
??? IDOTHER  ( type: esriFieldTypeInteger , alias: IDOTHER , Coded Values:  [100: Islands in Water] , [200: Water Series] , [300: Forestry Road] , ...44 more... )
??? ROLLX  ( type: esriFieldTypeString , alias: ROLLX , length: 13 )
??? PID  ( type: esriFieldTypeString , alias: PID , length: 11 )
??? TOTALHOUSE  ( type: esriFieldTypeInteger , alias: TOTALHOUSE )
??? LEGAL_PLAN  ( type: esriFieldTypeString , alias: LEGAL_PLAN , length: 8 )
??? BLOCK  ( type: esriFieldTypeString , alias: BLOCK , length: 5 )
??? LOT  ( type: esriFieldTypeString , alias: LOT , length: 5 )
??? SECTION  ( type: esriFieldTypeString , alias: SECTION , length: 4 )
??? TOWNSHIP  ( type: esriFieldTypeString , alias: TOWNSHIP , length: 4 )
??? RANGE  ( type: esriFieldTypeString , alias: RANGE , length: 2 )
??? MERIDIAN  ( type: esriFieldTypeString , alias: MERIDIAN , length: 1 )
??? DISTLOT  ( type: esriFieldTypeString , alias: DISTLOT , length: 5 )
??? LGL_SUBD  ( type: esriFieldTypeString , alias: LGL_SUBD , length: 2 )
??? STREET  ( type: esriFieldTypeString , alias: STREET , length: 25 )
??? LGL_DESC  ( type: esriFieldTypeString , alias: LGL_DESC , length: 100 )
??? SIZE_HA  ( type: esriFieldTypeDouble , alias: SIZE_HA )
??? OWNER_TYPE  ( type: esriFieldTypeString , alias: OWNER_TYPE , length: 1 , Coded Values:  ,
, , ...17 more... )
??? ELECT  ( type: esriFieldTypeString , alias: ELECT , length: 1 , Coded Values:  , , , ...3 more... )
??? GIS_TILE  ( type: esriFieldTypeString , alias: GIS_TILE , length: 2 , Coded Values:  [bb: blaeberry] , [dn: donald] , [kh: kicking_horse_river] , ...68 more... )
??? MAPSHEET  ( type: esriFieldTypeString , alias: MAPSHEET , length: 4 )
??? EDITDATE  ( type: esriFieldTypeDate , alias: EDITDATE , length: 36 )
??? EDITREASON  ( type: esriFieldTypeString , alias: EDITREASON , length: 3 , Coded Values:  [New: New feature] , [Chg: Change feature] , [Mis: Missing feature added] , ...1 more... )
??? Common_Name  ( type: esriFieldTypeString , alias: Common_Name , length: 30 )
??? EditPerson  ( type: esriFieldTypeString , alias: EditPerson , length: 5 , Coded Values:  [Don: Don Richmond] , [Olive: Olive Dodd] , [David: David Major] , ...2 more... )
??? Data_Source  ( type: esriFieldTypeString , alias: Data_Source , length: 10 , Coded Values:  [GPS: GPS] , [Ortho: Orthophoto] , [Estimate: Digitized Estimate] , ...9 more... )
??? Count_Polygons  ( type: esriFieldTypeInteger , alias: Count_Polygons )
??? Block_Plan  ( type: esriFieldTypeString , alias: Block_Plan , length: 50 )
??? Comment  ( type: esriFieldTypeString , alias: Comment , length: 150 )
??? CSRD_File  ( type: esriFieldTypeString , alias: CSRD_File , length: 25 )
??? Parcel_Doc  ( type: esriFieldTypeString , alias: Parcel_Doc , length: 15 )
??? Crown  ( type: esriFieldTypeString , alias: Crown , length: 3 , Coded Values:  ,
??? Shape  ( type: esriFieldTypeGeometry , alias: Shape )
??? testfield  ( type: esriFieldTypeInteger , alias: testfield )
??? Shape.STLength()  ( type: esriFieldTypeDouble , alias: Shape.STLength() )
Supported Operations:   Query   Generate Renderer   Return Updates
by Anonymous User
Not applicable
Resetting field ordering worked for me as well. Thanks a bunch!
LisaNelson
Thank you, thank you, thank you!!!
HezronPhilip
This should be marked as the right answer. Solved the issue without any fuss.
NicoleSulzberger
in my case a field got the wrong alias in the service after publishing it to ArcGIS Server:
{"name":"PR_PROZESS","type":"esriFieldTypeString","alias":"Shape.STArea())"
Manually reordering the fields helped in my case.
AlessandroValra
Reording also worked for me. Agree that this should be the accepetd answer. Thanks!
NielsGerrits
Thanks!
NathanHeickLACSD
I'm still getting this issue with ArcGIS Pro 2.9.6 and ArcGIS Server 10.6.1.  Hopefully, it's fixed in newer versions of ArcGIS Server.  Resetting the field order did the trick.
