Does webgisdr use the "backup location" setting in the datastore?
1501
07-02-2024 11:43 AM
SGTomlins
Enterprise Version 10.8.1
I can successfully run webgisdr, and backupdatastore.  Each by themselves work as designed for full backup.
I have been attempting to run an "incremental" webgisdr command.  I get what looks related to the bug:BUG-000147726.
The first time I try an incremental I get the error:
Failed to back up the Relational ArcGIS Data Store:
Url: https://blahblahville.wi.us:2443/arcgis.
{"jobId":"134293e7-e4bc-4e4c-931f-0e04172cf2f3","errorMessage":"Unable to create an incremental backup, as a full backup for the relational data store is not available. Create a full backup before you create an incremental backup.","description":"Create data store snapshot 20240702-100718-CDT-88-INCREMENTAL to \\\\ARGO-AZ\\ArcGIS Backups\\TempBackup\\Incremental\\WebGISSite1719934208754\\dataStore\\16e5b264-d230-4aeb-b8aa-dc1ddf32774a","lastModified":"2024-07-02 10:30","status":"failed"}
I ran the full then tried the incremental.  I get a different error:
Cannot get ancestors in the response of the request:
https://blahblahblah.WI.US:2443/arcgis/datastoreadmin/getCreatedSnapshot.
com.esri.arcgis.webgis.WebGISException: Cannot get ancestors in the response of the request:
https://blahblahville.wi.us:2443/arcgis/getCreatedSnapshot.
The wegisdr.properties file has a different backup location than the data store.  Is this a conflict?
Thanks in advance...
simoxu
by MVP Alum
MVP Alum
in webgisdr.properties file, you need to specify the SHARED_LOCATION and BACKUP_LOCATION. they are not related to your Datastore backup location.
Your portal, server and datastore machine need to have access (R/W) to the SHARED_LOCATION
RickeyFight
MVP Alum
@SGTomlins
We save our back up location to a different machine then the data store machine.
SGTomlins
@RickeyFight
Agreed.  What I am curious about is if there is any interaction between webgisdr and datastore parameters.
When webgisdr runs, does it use the settings of the datastore when it backs up the datastore?
simoxu
by MVP Alum
MVP Alum
SGTomlins
Much Obliged.  🙂
