Does the option "Feature Access" requires the database to be SDE?
3443
10
02-05-2013 01:25 PM
JamalNUMAN
Legendary Contributor
I???m not sure if the option that enables performing editing over the web requires the database to be SDE (not file or personal)
[ATTACH=CONFIG]21478[/ATTACH], [ATTACH=CONFIG]21479[/ATTACH]
Thank you
Best
Jamal
Jamal Numan
by Anonymous User
Not applicable
Original User: Jamal432@gmail.com
this image:
help you decide.
see also this video: http://video.esri.com/watch/1175/building-web-editing-applications-with-arcgis-10.1-for-server
Many thanks Domenico.
I had a look at this flowchart from your previous link that you have supplied.
My issue at this point is precise!
1. There are no �??side effects�?� when using the versioning without �??mover edits to base�?� in terms of losing capabilities such as
a. Archiving
b. Working with complex data
2. There are �??side effects�?� when using versions with �??mover edits to base�?� such as
a. Losing the archiving function
b. Losing to working with complex data
3. My understanding that the only difference between version with �??move edits to base�?� / without �??move edits to base�?� is that the edits are reflected directly to the database! Then who cares!
4. What people will lose if they choose all the time the without �??move edits to base�?� option EVEN IN CASE:
a.  THEY DON�??T NEED TO HAVE ARCHIVING FUNCTIONS
b. THEY DON�??T HAVE COMPLEX DATA
Based on what I read and the feedback, there is no need at all to have the �??move edits to base�?� option. We can all the time choose the option without �??move edits to base�?�.
Best
Jamal
