Wondeirng how everyone is going with this issue.
I am trying to publish the Data Extract Tool (clip and ship) ArcGIS Help 10.1 Followed the instructions. Published the map service OK but the GP service just wont publish successfully. It sort of did (I can see the service in catalog but in REST it just says ERROR 500)
Recently upgraded to 10.2.2
My above process worked with no issues before I recently upgraded.
Ever since the upgrade to 10.2.2 even most of my map services have issues publishing.
Any ideas would be great
Louise
If you want to install ArcFM Object Reader 10.2 with ArcGIS Server 10.2/10.2.1/10.2.2 and also want to publish your models or custom tools successfully, then you also need to install ArcFM server 10.2. I have tried it and successfully pulished my custom models as geoprocessing service.
If you do not have ArcFM Server Installation Files, then you will need to remove ArcFM Object Reader from your system.
Publishing Geoprocessing services need ArcGIS Server 10.2/10.2.1/10.2.2 alone on a machine or with ArcFM Object Reader 10.2 and ArcFM server 10.2.
Why this happens, I also do not know...
