Connecting to DataStore
1931
02-08-2021 02:02 AM
CliveSwan
Occasional Contributor II
Greetings,
You use and .ags file to connect to ArcGIS Server and a .sde file to connect to SDE.
What is the method to connect to the Enterprise DataStore - a PostgreSQL database?? I haven't found any information on the ArcGIS Enterprise webpage, that explains how to connect.
Any pointers appreciated.
Regards,
Clive
Tags (3)
George_Thompson
Esri Frequent Contributor
The DataStore is managed by the ArcGIS Enterprise deployment. It is not designed to be accessed directly via ArcGIS clients. You can use the DataStore tools (https://enterprise.arcgis.com/en/portal/latest/administer/windows/data-store-utility-reference.htm) to access some information.
Is there a specific reason that you want to connect directly to it?
--- George T.
CliveSwan
Hi George,
I want to list the data stored in the Data Store, ie just read the data content.
Is the hosted services content, the same as Data Store content??
Clive
HenryLindemann
Hi @CliveSwan
So each layer in a Hosted Feature Service will be a Table in the Datastore SQL with a few exceptions; The best solution is to just manage it out of portal because editing the data in datastore can corrupt items in portal.
