Connecting to 6443 Arcgis Server Certificate Not Match
1389
08-29-2019 08:26 AM
LloydBronn
Occasional Contributor II
When attempting to connect to our ArcGIS Server through 6443 or 6080 Inside of ArcMap (or when trying to publish a map service via python) I get the message "The Certificate you are viewing does not match the name of the site you are trying to view." This message just started happening over the weekend and as far as I can tell nothing has changed and the certificate is still in a valid timeframe.
AngusHooper1
Occasional Contributor III
If this was not happening previously then it is likely that the certificate has expired.
LloydBronn
Would this be the self signed certificate by the ArcGIS Server Machine? How to I make sure the 6443 certificate is correct?
RachelSears
Hi Lloyd,
If you changed your server communication settings from HTTP to HTTPS Only, or changed the name of your Server, you will need to generate a new self-signed certificate.
Configure ArcGIS Server with a self-signed certificate—ArcGIS Server Administration (Windows) | ArcG...
Hope this helps!
